All the policies listed here already contain a source address type that is configured to be dynamically inserted by Identity Manager. Hence these policies cannot be used with Identity Manager. Note: The message will be either "List of policies:" or "List of the first 50 policies:" depending on the number of policies that have a problem.
Remove the statically configured source address from the policy and then try adding the policy to Identity Manager. After this the access list source address type can be changed as desired.
Error
%count% %polType% already contain a %attrName%. %prefix% %policyList%
| Name | Type |
| count | uInt32 |
| polType | String |
| attrName | String |
| maxNumPol | uInt32 |
| prefix | String |
| policyList | String |
